Hi there. Not new to VDJ or decks - but Numark Party Mix output is distorted. Can't find a fix.
Any suggestions here folks?
Headphones are the only issue. It's garbled and distorted.
Yet, this doesnt happen in other software for this deck.
geposted Wed 18 May 22 @ 2:43 am
Try to turn it on
"exclusiveAudioAcces"
geposted Wed 18 May 22 @ 3:07 am
No change with exclusive audio access on or off
geposted Wed 18 May 22 @ 3:14 am
Is the latency changed better?
geposted Wed 18 May 22 @ 3:16 am
change "SampleRate" so that it becomes the same for all cards
geposted Wed 18 May 22 @ 3:17 am
try changing channels 3-4 or 5-6
geposted Wed 18 May 22 @ 3:23 am
tried latency of (was 256) tried 512 / 1024
by sample rate you mean on optoins -> search sample rate -> change to 44100, no luck.
channels 5/6 same issue
geposted Wed 18 May 22 @ 3:32 am
I think I found something to work here.
Tried recording this in OBS, and first test worked. grabbing my good headphones for another round
Then in OBS I set VB audio Voicemeter to record
and
headphones, or realtek defenition to mute
and
geposted Wed 18 May 22 @ 3:59 am
use ASIO4ALL driver
geposted Wed 18 May 22 @ 9:21 am
