There are a few keywords to setup Automix but I don't see one specifically to toggle on:
Automix Type = Smart
and
Automix Type = Fade Out / Cut In
I'm not sure if there is another way to quickly toggle between settings if I can't create a button for each setting.
and
geposted Tue 24 May 22 @ 10:37 pm
geposted Wed 25 May 22 @ 12:21 am
Thanks @GK.
Not exactly what I was looking for. Only one button in those 2 options do half of what I'd like to do.
In the "Automix Live" plugin there is a button that toggles between all the mix options.
I was really looking for the code to quickly click that would immediately change the mix type to
"Smart" then "Mixnow" which creates smart mix points then starts a mix
and a 2nd button for
"Fade Out,Cut In" then "Mixnow" which resets the mix points as appropriate then mixes now.
geposted Thu 26 May 22 @ 11:29 pm
