Been setting up some quick filters today and they are all working except the R&B one. Is there an issue with the "&" character perhaps?
geposted Wed 25 May 22 @ 1:53 pm
Did you try adding quotes? (contains "R&B")
geposted Wed 25 May 22 @ 1:56 pm
Cheers Adion, that works now. The other filters don't seem to need the quotes though, should I add them anyway?
geposted Wed 25 May 22 @ 2:25 pm
No need, only needed with special characters or spaces.
They are added automatically when needed when using the filter editor btw :)
geposted Wed 25 May 22 @ 2:40 pm
Brilliant, thanks for the info!
geposted Wed 25 May 22 @ 2:49 pm
