So I use the "Line In" feature in virtual dj every week to route spotify inside VDJ and use some audio FX
as I upgrade to the BUILD 6959 (2022-05-24) I notice that the audio coming from the "line in" was crackling a lot. As I downgrade to BUILD 6921 (2022-05-08) the crackling stopped.
Just reporting the issue so the vdj team can fix it before releasing as a finished version
geposted Fri 27 May 22 @ 4:39 am
Could not reproduce here.
What is your audio setup?
geposted Fri 27 May 22 @ 9:28 am
I Use a DDJ-SZ2.
My line input is through a virtual audio cable VB-Audio Cable, I set the output device on Spotify windows App as VB CABLE A and inside VDJ I set the LINE in input as VB AUDIO CABLE A and after the update to the BUILD 6959 I notice that from time to time... like every... minute or so the audio from the line in start to crack up for something like 5 to 10 seconds and back to normal.
After I downgrade to BUILD 6921 it's all normal.
I Can try record a video if you need it.
All the devices are setup to have 44.1khz as sample rate
geposted Sat 28 May 22 @ 12:15 am
Can you try if 6969 makes a difference?
geposted Sun 29 May 22 @ 9:10 am
I tested on B6969 and everything is fine, now I'm using B6972, I will test on Saturday (tomorrow) if everything is ok, I let you know. thanks a lot for the attention.
geposted Sat 04 Jun 22 @ 1:09 am
