Hi Team
I have a large number of tracks that have been cut to 20 second snippets of songs.
I am trying to use the color rules to mark all tracks shorter than 40 seconds to red so I don't accidentally play the short ones. But it is not working?
I have set the color red and then used the <= sign and not all short tracks have changed.
I have included a screenshot?
Thanks
Thanks
geposted Wed 23 Nov 22 @ 3:58 pm
Maybe it should be .40 because just 40 is 40 minutes possibly
geposted Wed 23 Nov 22 @ 5:00 pm
Are these Tracks added to the Database ? (can be searched ?)
It works fine here. Value is in seconds btw , so you made your Filter correctly.
However, unscanned tracks may also appear/colored, so best would be to add a second rule with lenght >0
geposted Wed 23 Nov 22 @ 7:37 pm
