In the file list section, how do you have track info on a single line? Track info is currently on 2 lines so nothing lines up with the field headers. My tracks are also listed in 2 to 3 columns, depending on the width of the file list browser. Please help.
geposted Sun 05 Feb 23 @ 5:55 am
Click on the cog near the bottom left, then change your display option to list view.
geposted Sun 05 Feb 23 @ 11:37 am
Thanks but i don't see anything of the sorts in the bottom left view. All i see in bottom left is browser options, font size and browser zoom. I went through browser options and nothing there works.
geposted Mon 06 Feb 23 @ 1:40 am
Just found the problem. The cog you mentioned was not there because the touchscreen mode was clicked. Thanks for your assistance
geposted Tue 07 Feb 23 @ 3:55 am
