and everything rested to the new skin..the old menu to select old school skin ..where is it? the old menu to my skin files?...I'm on windows 7 btw..and dont want to hear crap about that lol.....from sound sourse i would select shaders main controller..this is not showing...
geposted Sat 02 Dec 23 @ 5:43 am
oh..and I'm using the 16 pad sample pluging..but that is not showing where to select pads 9-16...this is not good..
geposted Sat 02 Dec 23 @ 6:34 am
so..i find a workaround ..sound source is available in the new skin..so i can click open the main shader gui with that,....then change skin to vdj 801..but this is'nt the skin either..its the one named "old"...which is not showing on the selection,nor the tree of extensions?.....oh...i've found the freaking thing...y'all moved it and renamed it as "audio only" on the right tab...jeeez...
geposted Sun 03 Dec 23 @ 12:12 am
This may inspire you
geposted Sun 03 Dec 23 @ 12:21 am
