I am thankful for the hashtag feature of filtering and adding personal tags in the User 1 & User 2 fields in the info bar, but there are personal tags created that are not see when i try to select a tag i hv already created.
There is need for a scroll bar on the side to be able to see the other tags that are there but aren't visible to the space given. The pic attached shows a full list of tags, but there are others not seen there and there's no way (i've found) that will allow me to find them here. The scroll bar will help alleviate this issue.
geposted Wed 14 Aug 24 @ 12:14 am
Yes please, it's very difficult to tag songs without seeing the tags that we are already using.
geposted Fri 22 May 26 @ 11:18 am
As tedious as this is, it is a work around. Add all your tabs into the favourite panel, they'll then appear in that list. Or at least they do for me
geposted Fri 22 May 26 @ 12:25 pm
Do u mean creating 'favorite folders' for the tags?
geposted Fri 22 May 26 @ 10:35 pm
If you click "edit" at the bottom of the list and then put all the your tags in the "favourite tabs" panel, they should all then appear in the list when you click it
geposted Sat 23 May 26 @ 7:13 am
You are confusing me, cause there's no edit feature at the lists in VDJ and i hv no idea what u mean by favourite tabs. The pic shows all the options that are available to 'lists'
U may need to provide some images to demonstrate what u are referring to.
geposted Sat 23 May 26 @ 1:11 pm
@shabba khe look at the picture in your first post. At the bottom of that list it says EDIT...
geposted Sat 23 May 26 @ 3:09 pm
