Please inform us because in the database the File Date field is not the date the file was created but the modification date.
geposted Sun 06 Oct 24 @ 7:39 pm
use "first seen"
geposted Sun 06 Oct 24 @ 9:08 pm
Τhe same result
geposted Thu 17 Oct 24 @ 6:34 pm
In the first appearance field, it shows the date from the day of installation and newer. So it doesn't read the file creation date.
geposted Thu 17 Oct 24 @ 6:49 pm
I have a Python script that can add any value to the User1 or User2 fields. So the date the file was created could be added to either of those.
Also, the script could be modified to change the "first seen" date to the file creation date instead.
geposted Fri 18 Oct 24 @ 11:51 am
Thank you very much, I will try it.
geposted Fri 18 Oct 24 @ 12:34 pm
I've sent you a PM
geposted Fri 18 Oct 24 @ 2:39 pm
