Hi, after the recent update it seems the beat counter is no longer visually working in the default skin pro and perfomance, has any one come across this issue?
it does seem to work in essentials and starter only
i tried looking for a color code in the xml file but no luck.
geposted Thu 13 Mar 25 @ 12:44 pm
Works fine here. Maybe give more info on the issue (especially if you made skin edits to the default)
geposted Thu 13 Mar 25 @ 2:05 pm
i have made no edits, but since it seems fine on your side i will do a clean fresh install and see how it goes.
Thanks
Thanks
geposted Thu 13 Mar 25 @ 5:14 pm
i can confirm a full reinstalled fixed it.. now to figure out where to replace my database files. as it used to sit in documents with the database but it no longer does..
thanks again for the reply
geposted Thu 13 Mar 25 @ 5:24 pm
geposted Thu 13 Mar 25 @ 5:42 pm
