Forum: Old versions
Topic: tccd only 6 minutes long?
raveHome userMember since 2004
Is there a possibility to make the track longer than 6minutes?
I am a trance dj and the most songs are longer than 6 minutes , so i would like to get longer versions of the tccd.
I hope someone can help me.
geposted Sat 13 May 06 @ 7:13 pm
Just a question: why do you use a CRACKED version ?
geposted Sat 13 May 06 @ 7:20 pm
sbangsPRO InfinityMember since 2004
tut tut , go buy it!
shame on ye
geposted Sun 14 May 06 @ 1:28 am
If the program works correct then i will buy it.
What do i do with a program that doesn't work properly.
I play trance , the songs are longer than 6 minutes.
After 6 minutes the song will stop playing becausethe tccd is too short.
And i should buy it while it doesn't work like it should.
Not me !
geposted Sun 14 May 06 @ 2:27 pm
apopsisdjPRO InfinitySenior staffMember since 2003
I can ensure you that the program is smart enough to allow the song playing even if it is longer than the timecode track. It's done automatically..., and works perfectly, at least with my version...
And btw. timecode is 12 min long not 6 min...
geposted Sun 14 May 06 @ 2:46 pm
sounds to me that u just confessed to piracy!
geposted Sun 14 May 06 @ 11:27 pm
Have you tried recording the timecode as an audio cd rather than a data cd?
geposted Sun 14 May 06 @ 11:40 pm
Yes , i've tried that
I even tried to put 2 versions of the tccd together , didn't work either
geposted Wed 17 May 06 @ 8:10 pm
it's very rare that your code is only 6 min long, since apopsis mentioned is 12 min long, maybe the link was broken when you downloaded the file, try again, my tccds work great!!
geposted Thu 18 May 06 @ 2:51 am
just a quick question , why are u still helping a cracked user?
geposted Thu 18 May 06 @ 10:17 am
It wasn't a question which would take too much time to try and make a helpful suggestion towards and there is the chance that if everything works correctly they will buy the software. I know a few of us on here have evaluated the program as it's meant to be used before buying it (no headphone prelistening in the trial, you're having a laugh aren't you..). Besides, the problem doesn't seem to be with the software but the timecode (or hardware).
geposted Thu 18 May 06 @ 12:33 pm
if you crack the trial you only get a poor limited version of the features such as messed up timecoding thats why its obvious its a crack.
geposted Fri 19 May 06 @ 10:31 am
There are valid keys and cracks for 3.4 full floating about from as long ago as March but this is all irrelevent. Anyone with an internet connection and CD Writer can download the MP3 Timecode signal and record it to a CD. Now if his CD deck is reporting it's only six minutes long, it has nothing to do with using cracked software or not.
geposted Fri 19 May 06 @ 1:33 pm
