Topic: Virtual DJ Pro/CUE 5.0 software upgrade
I am interested in purchasing the Numark "Total Control" Controller and DJ/IO Soundcard to hook up to my laptop (which has only a Pentium III processor).
I understand the Controller comes with CUE LE 5.0 software, which essentially is the same as the limited edition Virtual DJ software and which is compatible with a Pentium III processor. I need to make sure my laptop meets the minimum requirements for the CUE or Virtual DJ software upgrades before I purchase. If I purchase the Controller with the limited edition software that is included, and I want to upgrade to Cue 5.0 full version or Virtual DJ Pro, is either upgrade compatible with the limited versions and will my laptop meet the minimum requirements?
I feel that because my laptop is a Pentium III processor, it won't meet the minimum requirements for the (full version) CUE software upgrade (which requires a Pentium 4 3 GhZ computer). Does Virtual DJ Pro also require Pentium 4 3 GhZ computer? If this is the case, I will need to buy a newer laptop, correct?
I mean, is it possible for me to buy the Numark Controller, get the Virtual DJ software and then upgrade to Virtual DJ Pro, using a laptop with only a a Pentium III processor? I can't really afford a new laptop right now. PLEASE HELP!
geposted Tue 27 Nov 07 @ 4:06 pm
Basically, if I purchase the Numark "Total Control" Controller, I will only have CUE LE software which is equal to the home/djc edition of Virtual DJ, and I don’t get discount if I want to upgrade to full version of CUE 5.0, as opposed to the Virtual DJ home edition where I get the discount when I upgrade to Virtual DJ Pro.
It appears that the minimum requirements for the CUE LE and Virtual DJ home edition software are a computer with a Pentium III processor. However, the minimum requirements for the upgraded versions of CUE 5.0 or Virtual DJ Pro require a computer with a Pentium 4 3 GhZ, which my laptop DOES NOT HAVE.
Can someone tell me if it’s possible for me to buy the Numark Controller, get the Virtual DJ software and then upgrade to Virtual DJ Pro, using a laptop with only a Pentium III processor??
Hi djkfc123, u already have ur answer in the hardware section.. ;) Pls dun double post the same question. It will cause confusion. U can use the thread that u started in the hardware forum abt this topics. Thks.
