Since 2024 release VST effects on the left deck do not work at all. The plugins load but it is as the software is not publishing the audio to the plugin.
geposted Mon 29 Apr 24 @ 1:07 am
Just checked here and all working fine - but as you've given no details on your setup it's hard to say what the problem (for you) might be...
Computer and OS details. VDJ build. Name and type of VST (i.e. VST3?).
geposted Mon 29 Apr 24 @ 8:57 am
Windows 11, VST3 (Waves), DJM-S9 as interface.
geposted Wed 01 May 24 @ 7:48 pm
OK we're one step nearer, but which Waves plugin(s)? There are over 200.
I use Waves myself, so I can try it here.......given the required info.
geposted Wed 01 May 24 @ 9:33 pm
Ah sorry, in this case it's any VST PLUGIN, not just waves. The primary one I use is abbey road, but also other vsts have issues that are not waves.
geposted Sun 05 May 24 @ 1:04 pm
All Vsts have the same issue on the left deck where it doesn't seem they are receiving any audio buffer. I am running an asus ROG zephyrus G5. I've tested this with 5 VSTs so far, waves and non-waves and they all exhibit the same issue.
geposted Wed 08 May 24 @ 1:58 pm
So if I switch the fx to be pre-fader it fixes the issue on teh left deck, if I set it back to post fader the issue reappears.
geposted Sat 11 May 24 @ 10:42 pm
Might help to post your audio config. Also, I believe pre- and post-fader effects only affects certain built-in effects (e.g., echo, reverb). The rest all stay pre-fader. So it’s confusing.
geposted Sun 12 May 24 @ 9:38 pm
Audio config is simply DJM S9 setup using the default profile that comes with virtual DJ. It for some reasons seems to be treating the VSTs as post fader effects and is not getting an audio return back but only on the left side.
geposted 7 days ago @ 9:55 pm
If not mistaken, the DJM-S9 only has one fx send/return channel, so it's important that you use the buttons and paddles on the S9 to enable the effects to make sure the send/return channel is operating on the correct deck.
geposted 6 days ago @ 7:19 am
Right but this seems to be unrelated to that. As before the audio would pass through prefader per channel without any configuration changing. Anyway a temporary solve has been setting fx to prefader.
geposted 4 days ago @ 2:33 pm
