Topic: Is there a way to completely remove & re-initiate cuepoints?
SepatroPRO InfinityMember since 2019
Hello,
I messed up with a song (added too much BeatGrid points, deleted automix points, ....) - so in short, I would like to remove all cuepoints and have VDJ take a fresh look. I could of course remove it from the search database and add it again, but then I would have to find this song again etc - which is not always obvious. Is there an easy way to get a "fresh restart" on cuepoints?
geposted Wed 01 May 24 @ 5:06 pm
Just go in to the POI editor and delete them from there.
geposted Wed 01 May 24 @ 6:38 pm
But then they are gone. How are the default pois added again?
geposted Wed 01 May 24 @ 7:28 pm
Reanalyze
geposted Wed 01 May 24 @ 8:01 pm
Thanks! That did the thing :)
geposted Fri 03 May 24 @ 11:08 am
