Topic: using a different controller
Good day.please can i use my VDJ on a different controller?
M.y friend is having a party in the US and i will be Djing .i will be going with my laptop where i already have my VDJ installed.
Will it allow me to use a different controller because it is register to my current controller.
what do i need to do to enable me use a different controller without any restriction.
your advice will be highly appreciated
geposted Thu 02 May 24 @ 8:03 am
You have a pro licence, you can just login with your credentials and use any machine with vdj installed with any/all supported hardware.
Nothing else to it as far as vdj is concerned just login. Usual machine to device communication applies, install drivers and what have you.
geposted Thu 02 May 24 @ 8:35 am
Home license = permitted to use VirtualDJ with which specific model(s) of controller you have paid to use without restriction.
Pro license = permitted to use VirtualDJ with any model of contrroller without restriction.
So long as the computer you use has either a Home license for the controller you are going to use or has (or you have) a Pro license for use then you will not have any issue.
geposted Thu 02 May 24 @ 7:13 pm
computers don't have licences, people do.
geposted Thu 02 May 24 @ 8:10 pm
True. I misspoke. I stand corrected.
geposted Wed 08 May 24 @ 5:27 am
