Forum: Wishes and new features
Topic: Denon DN-HS5500 updates
Better USB connectivity (no disconnections) (Vista)
Fix the platter issues (latency, slipping, freezing)
Allow use of 2 controllers via MIDI
Thank You,
Taipanic
geposted Mon 24 Nov 08 @ 2:08 am
Why wouldn't this already be possible? Use a different midi port for
each defice or different channel.
So are you saying that the 5500 is already supported with the default mapper if you have 2 devices (left & right)?
Ross
Native support only allows 1 player to be connected at this time. If two player native support is enabled, there is an option in the Denon's config to make a second controller operate on channels 3&4. Reflex currently has native support for 2 HS5500s, hopefully we will too soon. Right now I am more concerned about having better platter functionality...
Taipanic
