Can this be used with timecoded vinyls? It supports asio so i should think so.
its just that on the products page it doesent say anything about TCV but the othersound cards do.
my friend only wants this soundcard because its the cheapest
geposted Sat 06 Dec 08 @ 7:41 pm
no.
the numark i/o only supports 2 stereo outputs. for a timecode function you need with 2x stereo outputs and 2x stereo inputs.
geposted Sat 06 Dec 08 @ 10:14 pm
i have the numark sound card but really the sound quilaty not goood..the sound card on my desk top computer sounds WAYYYY better...
geposted Sun 07 Dec 08 @ 12:34 am
ok my friend is using nurmak cue, and he wants to know what is the cheapest soundcard box he can buy so he can use timecoded vinyls with a external mixer, decks and nurmak cue itself. He also knows that he can buy vdj time coded vinyls, but will the work with cue?
if not can you buy numark timecoded vinyls seperatly?
geposted Sun 07 Dec 08 @ 3:45 pm
ok ive been using the djio card since i got vdj and its a great soundcard but only for soundcard never let me down.two stero outputs plus mic and ephones.ive upgraded to rmx but still use djio in different pubs and strill ok
geposted Sun 07 Dec 08 @ 7:54 pm
the VDJ timecoded vynils will work with cue since cue and VDJ are the SAME judt different names and default skins..the cheapest would be the maya 44..to connect the turntables..DJ IO doesnt have enough outs and ins for a timecode use...
geposted Mon 08 Dec 08 @ 7:37 am
is the behringer u-control a good soundcard? you can hook up at least one turntable i think.
geposted Mon 08 Dec 08 @ 4:04 pm
Would this soundcard (the Numark i/o) send players 1 and 2 of Virtual DJ 5.2 to 2 seperate channels on an outboard mixer?
Also...I have a Dell Inspiron 1420. Would the Numark be a significant improvement in sound quality?
Thank you!
Thank you!
geposted Mon 08 Dec 08 @ 8:27 pm
no u cant connect the DJ IO to another mixer....since it doesnt have a input to for a mixer..u would have to have another mixer..but it well play the songs from deck A and DECK B if thats wut u wanna know..the sound quality for me i really think it can be better...
geposted Mon 08 Dec 08 @ 8:36 pm
Thank you!
Thank you!
The DJ i/o has a 25bit soundcard in it. The quality is better than the RMX but not as good as an Audio8. Everything is subjective depending on your needs. With a set of RCA outputs it can be slaved to en external mixer, or effects like an EQ or maximizer, to improve over all sound quality. But it is not suitable for most stand alone applications, or for time code use. I have had mine for over a year now and it has served me well when used in conjunction with a mixer (to improve its sound quality).
But, to answer your question, no. It does not have assignable outputs for each independent "deck" or "player".
geposted Mon 08 Dec 08 @ 8:47 pm
Thank you so much TearEmUp. : ) Very helpful. What would I need to get to achieve seperate sends for the decks?
geposted Mon 08 Dec 08 @ 9:17 pm
thanks alot for the help everyone:) I think im going to go with the maya instead.
geposted Tue 09 Dec 08 @ 6:03 am
is there a similar soundcard on the market that does more or less what dj/io does but with a better sound quality.?
no matter what I try with this puppy I just can't get used to it's 'squashed' sounding characteristics :(
makes my pa sound compressed, even with a quality 32 band dual eq hooked up !
geposted Tue 18 Jan 11 @ 4:51 pm
well, im glad this has come up. i was going to ask the same question myself before i decided to buy one tomorrow. thanks guys. ill stick with my maya 44 pci for now.
looks like its going to be new mixer and new styli for my concord dj s carts.
hopefully ill get the usb maya44 after the weekend. unless anyone knows of a cheaper equal quality item?
geposted Tue 18 Jan 11 @ 5:04 pm
@ TearEmUp...I may have read your reply incorrectly, but you can assign the two outputs from the DJIO to separate input channels on an external mixer.
In one of my rigs, I use the DJIO connected thus:
1) DJIO connected to laptop via USB.
2) Output 1 on DJIO connected to channel 1 input (via Line In) on my DDM4000.
3) Output 2 on DJIO connected to channel 2 input (via Line In) on my DDM4000.
4) Headphones connected to the headphone socket on DDM4000.
5) Mic into Mic channel of mixer.
Virtual DJ Sound Config:
Inputs: NONE
Outputs: External Mixer (Deck 1 : Left Channel / Deck 2 : Right Channel)
Sound Card: ASIO Driver - Numark USB Audio Device.
Virtual DJ now sends the audio from each deck, unaltered by any inbuilt audio control, directly to the mixer, whose controls are now used to alter the audio. PFL is handled by the PFL selection on the mixer, etc, etc - Basically in this config, the mixer is receiving the audio signal in the same way as it would if I had connected CDJ's (which I do, I connect the audio outputs of my NDX800's to channels 3 and 4 of the DDM4000, so that I can swap between CD / USB stick or MIDI).
Again, I apologise in advance if I read your reply incorrectly.
Simon
Inputs: NONE
Simon
geposted Tue 18 Jan 11 @ 6:30 pm
Simon, look at the date of my post. It is 2 years old Numark has updated the firmware several times, hence some things have changed....
geposted Tue 18 Jan 11 @ 6:33 pm
TearEmUp...oops...Sorry about that... :)
geposted Tue 18 Jan 11 @ 6:35 pm
lol
geposted Tue 18 Jan 11 @ 7:03 pm
just been looking at the Deejay Trim
may be just what I need to kill two birds with one stone too !
It looks a better deal than the dj/io with improved signal carriers like 1/4 inch outs
also, I need a provision for a cd player and this bad boy has line ins, for cd and turntables so kinda combines mixer capabilities with a soundcard !
just without the faders ;)
has built-in hub for 3 usb devices too for more stability me thinks, and has its own ac adapter power supply.
mic in and with talk-over, could this be the solution to my problem ?
anybody using one at the moment ? if so, what's the verdict !
geposted Tue 18 Jan 11 @ 7:39 pm
Hey
I just got the Numark IO sound card and im trying to connect my numark tt-200 vynl turntable to it. Now when i go to config setting to switch to single timecode cuz i only got one turntable it says error on asio driver????? now my mixer seem to work both channels but its not picking up my turntable?????? not sure if i got the rc cables connect right or something but i need help big time plz hit me up asap thanks
geposted Sat 12 Mar 11 @ 6:21 pm
