Hi, I would love to be able to select 3 sound cards to use with Vdj so to be able to assign samples to an independent channel in a 3 line mixer.
This is partially possible already, using 2 sound cards (4.1 + stereo) but I'm using the numark cm200 usb, which already uses two usb sound cards connections (stereo + stereo), therefore leaving out the possibility to assign samples to a third channel.
Looping samples (beats) not always synchronize to the playing track the way you expect them, making it risky to use in a gig.
thank you.
thank you.
geposted Tue 23 Dec 08 @ 6:00 am
You can do it at the moment by two sound cards.
For example 2 channels of first card for channel 1, 2 channels of the same card for channel 2 and 2 channels of second card for samples (of course you need at least one 4 channels card).
geposted Tue 23 Dec 08 @ 6:29 am
