Why did the looping function change from ver 5.1 to 5.2, Is there a why to change this so the loop is in use with out being an effect (like it was in 5.1)
geposted Mon 29 Dec 08 @ 1:17 pm
There is a problem with the 5.2 and the rmx. it doesn't map right or something. If you search I think under hardware you will find it. I had to contact VDJ and they set up a special download so I go back to 5.1. Hope this helps.
Jeff
Jeff
geposted Mon 29 Dec 08 @ 8:16 pm
do you think this would get fixed? or it wont be til like 5.3 or something
I want to buy the pro version,but i havent made the jump yet
geposted Tue 30 Dec 08 @ 7:25 pm
Yeah they will probably fix it. Just don't go higher than 5.1 until they fix it.
P.S. Buy the pro at the discounted price. I purchase the pro first then purchased the RMX.
Jeff
Jeff
geposted Tue 30 Dec 08 @ 10:02 pm
excellent
so if i get the pro i can choose to download 5.1?
cause then thatd be awesome
geposted Tue 30 Dec 08 @ 11:17 pm
