Topic: Printing Out History - Page: 2
Can this tool work for Mac?
Andrew87 wrote :
Hehe thanks. I'll add the ability to browse for the tracklisting file in the next version, I left it out for now because I'm not sure the My Documents folder is accessible by other users. The thing I would like to refine most is the html layout, e.g. option to output as a table and a better layout.
I don't believe security is an issue for most people.
I reckon most people who do not have a dedicated DJ PC will simply have a different windows profile for use when jocking, and a different one for everything else! Both profile will be administrators so will be able to see each other's my documents folder!
For me I only use my DJPC for just that, DJing. I do not even have a keyboard plugged in (I use the virtual keyboard)! I use another computer to sync my music and remotely manage the machine, so it would be great to have an 'open database' option where I can simple network browse to the history file!
This feature would allow me to generate my playlists after a mix without the need to actually be on the computer!
Hope this makes sense and thank you once again for this priceless tool =Þ
when i try to install this i get the message "virtualdj has encountered a porblem and needs to close" any ideas?
Sorry for a little go out of thread, but is this also possible for vdj playlists or can be create?
Thx's
Haui
No as it is .exe not dmg for the application part.
However it should work in bootcamp.
djsynystr if you're running Windows XP you need the .NET Framework 2, but there's still some bugs I need to sort out before I'd recommend doing so.
djsynystr the program should run on a MAC if you use Mono but I don't know what the filepaths are on a Mac to automatically load up data and it may be buggy.
DJAuz that seems like a good idea, do you use external harddrives on that machine? I'd have to add the ability to manually load each database in the event of a network share as I don't think it's possible to do it automatically as the drive paths would be unknown.
Haui70 I could add a feature to print out playlists as well as history, maybe soon.
@ Andrew87, will be great.
Don't hurry and a great Job!:-)
THX
Haui
This has been needed for a LONG time, good job mate ;o)
