Hello
I found and bought a perfect controller for the sampler section of CUE, it´s called Korg nanoKontrol.
It runs by USB and sends standard MIDI, so it was pretty easy to map it into CUE.
Just a tip, but I really recommend it.
More can be found at http://www.korgnano.com/
Regards,
Regards,
geposted Mon 05 Jan 09 @ 8:12 am
Have you mapped the nanokontrol for virtual dj??
geposted Sun 22 Mar 09 @ 7:22 am
