hi there as you have already guessed i am a beginner at djing. i have a song on each deck on the virtual dj skin. is there anyway possible they i can press start and they will both start at the same time?
geposted Mon 05 Jan 09 @ 2:01 pm
As far as I know you could configure a keyboard shortcut to do this for you yes!
Please have a look at the manual to find out how this is done, the manual can be found here ; http://www.virtualdj.com/images/pdf/VirtualDJ%205.1%20-%20User%20Guide.pdf
Also don't forget to go here http://www.virtualdj.com/users/edit.html and enter the serial key from your Atomix Product ;)
Good Luck =Þ
Good Luck =Þ
geposted Mon 05 Jan 09 @ 11:39 pm
I am kind of new to the VDJ scene as well. I believe that if you left click "automix," it will automatically start both songs in sync. I believe right clicking will cause it to auto-fade through the playlist. Not sure though. Hope it helps.
You can do it by assigning a hot key for example "3" (number 3 button) in Config -> Mappers.
Press "+" button.
For "Key:" field type: "3"
For "Action:" field type the following text: "deck 1 play_pause & deck 2 play_pause"
Save changes and try "3" hot key
Press "+" button.
geposted Tue 04 Dec 12 @ 12:54 pm
You're almost four years too late!
geposted Tue 04 Dec 12 @ 1:07 pm
