how do i get rid of the popping and clicking when loading a song?
this sometimes happens when the song is playing and the bride and groom give me dirty looks.
help
dj@gvmusic.com
help
dj@gvmusic.com
geposted Thu 17 Feb 05 @ 10:59 pm
Do you have the same audio problems when the console is not plugged in?
geposted Fri 18 Feb 05 @ 7:40 am
You need more ram!!!
geposted Fri 18 Feb 05 @ 9:51 am
i don't hear anything from the laptop speakers when the console is not connected.
i have 1gb of ram isn't that enough?
geposted Sat 19 Feb 05 @ 8:21 am
If you have one gig of ram, you should set your "Max Load" in settings-general to Always, or at least 30mn. If it still skips on songs loading- your songs are either to long, or your processor to slow.
Also, even though I use TCV, I NEVER touch ANYTHING while i set a song to a deck and it loads. Just let the opposite deck play and don't touch anything until it's all loaded. Crossfading or scratching or even eqing on the herc and put excess pressure on your ram and CPU that can cause it to pop or skip.
geposted Sat 19 Feb 05 @ 8:57 am
i get a loud crackle noise at the start of every mp3 i play.. its easy to avoid.. ive learned to nudge the song over half a second before playing.. but does anyone else get this problem?
geposted Wed 23 Feb 05 @ 7:28 am
@goatus........ what version are you using?
gday mate
Andre
gday mate
Andre
geposted Wed 23 Feb 05 @ 9:16 am
i'm also having the very same problem, and its not the ram or the processor - and as for that it could be that the song is too long!!!!! why should that be a problem? dance remixes and part multitrack mixes are usually longer than 'normal' tracks anyway - isnt this aimed at dj mixing????
geposted Wed 23 Feb 05 @ 10:02 pm
im running the latest update.
but anyways.. i fixed the problem.. i think i know what it was. i didnt have enuff ram b4.. so i had max load turned off. Now i just upgraded my ram and turned max load on theres no crackle at the start.. i would say it was the gain being at infinite % for the first milisencond b4 it loaded the first second of the song and auto gained it down. If that makes sense... heh.
geposted Sun 27 Feb 05 @ 5:38 pm
@goatus:please enter your serial# in your profile
geposted Sun 27 Feb 05 @ 9:01 pm
i dont see the need or advantage of doing so.
geposted Mon 28 Feb 05 @ 7:02 am
i have 1gb of ram, p4 3.2ghz procesor new laptop.
help me get rid of the popping please, it is random and not always on the same song
geposted Wed 02 Mar 05 @ 1:47 am
i have never experienced or heard of this happening during the song playing.. have you checked your setup/soundcard etc for loose connections?
geposted Wed 02 Mar 05 @ 5:10 am
goatus- Register yo'self.
gvmusic- you ARE using a DJ console right? or are you just using the program...I don't see DJ console by name, thats why i ask.
geposted Wed 02 Mar 05 @ 8:53 am
Load priority set it to idle this will fix your issue on VDJ 8 with loading a song and getting crackles and pops in the master out
geposted Mon 14 May 18 @ 2:15 pm
Replying to a thread that was last visited 13 year ago... pointless
geposted Mon 14 May 18 @ 2:51 pm
