OK, I want to connect the MIDI on my Pioneer DJM 800 to my laptop so that I can control the crossfader while mixing video. I guess I would need a midi to USB cable? Like this one http://www.brilliantstore.com/computer_cables_dekcell_cpa_1281.html Please help me on this I am not sure what to do. Thanks
geposted Fri 09 Jan 09 @ 3:44 pm
Yes, that cable is good for connecting the Pioneer DJM 800 to your laptop!!
geposted Fri 09 Jan 09 @ 4:06 pm
After I connect that cable, what do I have to do in Virtual DJ to make it see it.
geposted Fri 09 Jan 09 @ 4:11 pm
1- activate general midi on VDJ
2- activate midi on the mixer (button midi on/off)
3- press start/stop on the right bottom of the mixer to synchronize the mixer with VDJ
4- in VDJ, configuration, external controller, right click on general midi, configurate
5- choose the functions, one by one, you want (fader, bass...) and assign a control (on the mixer) by pressing on the button.
geposted Fri 09 Jan 09 @ 4:19 pm
Thanks!!!
geposted Fri 09 Jan 09 @ 4:29 pm
For further information you can read pag. 19 of the manual of your mixer.
You are welcome!!
You are welcome!!
geposted Fri 09 Jan 09 @ 4:32 pm
No matter what I do I cant get this thing to work. The on/off button you are talking about is for the effects on and off. I started the midi I went to midi in VDJ selected crossfader and it is not showing up in the main screen after I hit ok. Can someonre please help, I want to try video tonight.
geposted Fri 23 Jan 09 @ 1:37 pm
I don´t really remember what i did when i have it, I think i had to activate midi on mixer, then VDJ recognized midi msgs. Be sure to connect correct midi plug into mixer if you have 2 of them at cable (in and out).
geposted Fri 23 Jan 09 @ 2:20 pm
I got it to work, I had the wrong midi cable plugged into the mixer. Sorry if I had a similar question in a different topic, It is ok to shoot me now...
geposted Fri 23 Jan 09 @ 2:30 pm
