Forum: Wishes and new features
Topic: Assign a sample to scratch
Like on the denon 3500 cd player.
Thanks
geposted Tue 13 Jan 09 @ 5:11 pm
great idea, i think this has been already been asked for.
If you're using the denon - why not just burn off a samples CD and use that to scratch? Vinyl would be a bit harder tho but there are sample vinyls out there - Q-Bert's SuperSeal for example.
Then you can run the CD player into a third channel or turntable into a phono input.
but i do like the idea of making the sample controllable from tcv. just not sure if its possible at the moment
This would be a great feature. The sampler can actually have a toggle as to what turntable/Deck it gets controlled of and the playing sample will be controlled of that decks beat which currently is until you use the other deck the same time.
Perhaps even a 3rd Pitch control for the samples instead of going of a decks Pitch it should have its own as to allow you to stretch that sound for multiple type of scratching techniques.
Now what would be really great is assign 2 samples to either deck and beat juggle with a 3rd sample keeping the beat. Each sample will then require its own pitch control.
Anybody know where I can get a good Scratch sample?
Joey....
There are heaps available online. My record pool has them available there
www.franchiserecordpool.com
Thanks DJMarze
Joey...
