Topic: AUTOMIX Help
I recently upgraded to 5.2 from 4.2. I love the loading of 2 tracks on one deck for automix. My problem is how can I mix into the 2nd song on the automix deck without going to the end of song one. Basically end song one in the middle and start song 2 on the same deck. In 4.2 it was as easy as hitting the automix button on top of the internal mixer skin. Thanks.
geposted Sun 18 Jan 09 @ 7:36 am
Double click the song you want to play in your playlist.
geposted Sun 18 Jan 09 @ 7:47 am
Thanks. Thats exactly what I was looking for. Now one more question, I want to fade to deck 2 from deck one in the middle of a song with out moving the fader manually. Is there a button that will mix it for me like the 4.2? I know, I am lazy!!!! LOL.
geposted Sun 18 Jan 09 @ 7:54 am
Haui70PRO InfinitySenior staffMember since 2008
Hy,
do you also speak from automix?
As i know is the information from tophouse the only one.
If you don't use automix und you want move the slider with one click, go to the effect download section.
If i remember right ist there an effect you can slide to the other deck by do a click.
Bye
Haui
geposted Sun 18 Jan 09 @ 3:26 pm
Have a look in keyboard shortuts, I think it's called 'mixnow' I know it's been discussed before on the forum so maybe a search for 'mixnow' will turn up what you want.
geposted Tue 20 Jan 09 @ 7:40 pm
