Hi,
Does anyone know about any software which I can use to play movies on messenger?
I will really appreciate if someone could help me out here.
Thank you and advance
geposted Thu 22 Jan 09 @ 7:10 am
give a piece of software called 'SPLITCAM' a try
its main purpose is to share a web cam between applications, but it set up a 'virtual camera device'
then within the splitcam main program, insted of selecting a webcam, there is an opton to play an mpeg file (with audio)
then in your messenger program, just open the webcam option and direct your messenger to the splitcam device.
hope this helps
http://www.splitcamera.com/
hope this helps
geposted Thu 22 Jan 09 @ 10:21 am
