Forum: Music discussion
Topic: MAsh up program and site?
wcjchanHome userMember since 2009
Hi there,
Does anyone know any easy to use Mash-up program.. Just new to this game..
Thanks for all your help..
Also is there any good House/ Trance/ Tribal mash-up site to guy good mix?
I personally loved hi energy music..
Thanks again
Johnson
geposted Sun 25 Jan 09 @ 8:41 pm
Virtual Dj is aa simple program to make mash=ups with
geposted Sun 25 Jan 09 @ 11:06 pm
Thanks but I mean more than just mixing 2 songs.. Something you can layer and edit quite
a lot.
Thanks
JOhnson
geposted Mon 26 Jan 09 @ 6:00 am
again i say virtual dj.... you can use all the sample banks and the recording features. I strongly suggest not looking for the magic software solution and use what is available at the monent.... creativity trumps technique almost all the time
geposted Mon 26 Jan 09 @ 10:52 am
You're looking more at music production software than DJ software, so have a look for those kinds of applications. What you use will depend on exactly what you want to accomplish, how you like to work, what your budget is and how skilled you are!
Some examples:
* Sony ACID Pro
* Cakewalk Sonar
* Steinberg Cubase
* Steinberg Nuendo
* Propellerheads Reason
* REAPER
* Logic Studio
* Magix Samplitude
* Renoise (a good old fashioned tracker)
geposted Fri 30 Jan 09 @ 10:59 am
Try Audacity, it's not bad and it is free
geposted Tue 10 Feb 09 @ 5:35 am
Oh yes, in Australia it is illegal to make mash ups without the record companies permission. So using VDJ to do it live is best. Practice alot before you do it live. Using samples and loops you can do some sic stuff. If you do make a mash up, do not play it live in a venue as it may cost you a fortune :-)
geposted Tue 10 Feb 09 @ 5:39 am
Abelton Live
geposted Wed 11 Feb 09 @ 3:47 am
