Forum: Wishes and new features
Topic: Total recording time
Maybe it's usefull, when you're recording your music and split it in multiple files, that you can see not only the recordin time of the current track, but also the recodring time in total (of all the tracks you've already played). No?
geposted Wed 28 Jan 09 @ 9:50 am
+1
+2 ....in the mean time, some skins have a timer you can click on that will count for you. Just get the timer going once you start recording your set. Unfortunately the timer will reset after 60 min so you just need to keep track and do some math. (If after and hour or so the timer says 5 min youve been recording for 65 min)
+3
it would be awesome if the record option created a cue file that has the track name and time as well as the track nr (traktor does this and so does mixmister and ableton) that way when you do record with intent to burn a cd it has the track spaces already marked and when you burn using nero and the .cue file it comes out ready to go!... d-.-b
