| Autor | - Topic: Herculess DJC MK2 Error - |
Hi guys I am using Herculess DJC MK2 many years. But now the console is not working anymore. When I plug it in the buttons are shining but neither the PC recognises a new device nor the dj softweare recognizes it. Got the same porblen on my Apple Power Book longer time ago. I do not now waht is wrong? Perhaps there was an error during firmware Update. Thank you very much PC: OS: Win XP XP2 Athlon XP 2100+8 (1.7 GB) 512 MB DDR Ram |
Ive got the same problem! anyone with a solution? im using a DELL Latitude 620 |
Can you define the problem a little bit? Did you just buy the console or was it installed on this computer previously? If it was previously working, what happened between the moment it was and now ? If this is your first installation, did you noticed any error messages during the installation process? Did you try the latest driver (4.HDJS.2009)? http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=177&cid=1 |
Hi Phatso, im guessing ive got the same problem as roop, a long time ago i disconnected my mk2 from a firmware upgrade, since then the console is not being recognized, in any way, by windows even tho the lights turn on (and stay on), I even tried in different computers and the manual firmware upgrade unsuccessfully since the device is simply not recognized by the system. Any ideas? DV |
Yes, exactly. I didnt really manage to do it since the console is not recognized when i plug it in... |
Hello cipo86, Are you sure you have kept pushing down the talk-over button while connecting the USB plug? |
hi MIB yes I have, doestn make any difference :( |
Hello cipo86, Then I suggest you call Hercules tech support while you are in front of your computer with your DJ Console Mk2. The phone number and hours are written on http://ts.hercules.com/eng/index.php?pg=contact . |
