Forum: Old versions
Topic: Denon DNS 1200 set up PROBLEMS!!!!!
I tried my single denon dns1200 on virtual dj and it worked perfectly, so I though I will get another one!!
However I just cant seem to get both working, Any ideas the correct way they should be set up so left deck controls virtual deck 1 and the right deck controls virtual deck 2.
I am using an Apple Mac book if that makes any difference!! is there a specia set up in the computer so it can see 2 decks maybe???
Thanks in advance.
David
geposted Sat 28 Feb 09 @ 7:06 am
Sorry, only 1 Denon DNS-1200 is natively supported at the moment. The use of two natively should be possible in the next version of VirtualDJ.
In the mean time, the only way to use two at the same time is via the general MIDI mapper, however LED and text displays will not function in this mode. You can download a ready-made MIDI map from the following page:
http://www.virtualdj.com/addons/6717/DN-S1200_MIDI_Mapper.html
Thanks for your reply,
I have downloaded the link in mac version for my mac book which seems to be a long list. What do I do next ?? I have never had to set a up a midi map?? Where do I start??
Thanks
David.
To load a general MIDI map, please do the following (These instructions are for PC version, but it should be the same/similar on Mac):
  • Go to CONFIG -> Remote Control in VirtualDJ.
  • Make sure the MIDI controllers are connected and switched on.
  • Click on General MIDI and choose Activate (The icon should go green.)
  • Click on General MIDI and click on the LOAD button.
  • Browse to the MIDI map file you downloaded.
  • Click on it and choose OK to load the MIDI map.
thanks for that, have managed to load it all, but i have 2 dns1200s plugged in and both decks only seem to controlthe left player, any ideas?
I have put one deck into one usb on the laptop and the otherinto a seperate usb?
please help, i have a gig in 4 hrs
thanks
David
Well this is definitely waiting to the last minute ...
I would suggest you only use 1 for you gig ... unless you are able to change the MIDI channel for your 2nd 1200 to Channel 2. And then map all the functions over for the 2nd 1200 so they respond to the MIDI Chan 2 calls.
hi can i use my dennon dns 1200 on virtual dj 5.2. i tried to hook up the cd player to the software and it wont play track's when i load them.
DN-S1200 is supported in VirtualDJ v5.2, but only one unit can be used. Make sure each unit is on the default MIDI channel 1.
For best results, you should upgrade to the latest v7.04 version of the software for free by going to http://www.virtualdj.com/download/updates.html
This will allow you to use 2 (Or more) units and also optionally customise the button mappings if you wish to suit your own preferences (This is not possible in VirtualDJ v5.2)
