There is currently a problem installing Virtual DJ with NOD32 enabled, as NOD32 mistakes one of VDJ files for being bad, and its of course not ;) (same problem with other software installs too)
So here is an image on how to fix it, for those with Nod32 installed...
After VDJ is installed, nod32 must be enabled again
geposted Sat 07 Mar 09 @ 10:49 am
what if we, or me, do not have that system installed??
geposted Mon 09 Mar 09 @ 3:26 pm
If you don't have NOD32, then you don't have to worry, since you won't have this problem.
geposted Mon 09 Mar 09 @ 6:41 pm
happend to me today... good to know.
geposted Sun 22 Mar 09 @ 9:30 pm
I will have the same problem with the eset smart security 4....?
geposted Wed 17 Jun 09 @ 12:58 pm
Hello, I have just installed the update, now I cannot get the song to play. The program is open but both pressing the play button on both decs does nothing.
I have a dell laptop with 4 gig ram. This never happened in the past form.
geposted Mon 22 Jun 09 @ 3:37 pm
excellent info, thanks for the easy to follow directions!
Scott
Scott
geposted Tue 14 Jul 09 @ 6:22 pm
lol
geposted Tue 11 Aug 09 @ 8:24 pm
Please can any one help me, i am using windows and having protection error 16.
geposted Mon 02 Nov 09 @ 3:21 pm
Please contact support: http://www.virtualdj.com/contact/index.html
geposted Tue 03 Nov 09 @ 12:39 pm
my computer will not detect this console...why?
geposted Fri 06 Nov 09 @ 7:35 pm
Try updating the DJ console drivers and firmware:
http://www.virtualdj.com/wiki/Common_Device_Drivers.html
geposted Sat 07 Nov 09 @ 1:51 pm
geposted Mon 30 Nov 09 @ 7:41 pm
geposted Sun 20 Dec 09 @ 3:30 pm
With System Monitor Disable (AMON Disable) you can install VirtualDJ too.
geposted Wed 06 Jan 10 @ 2:07 pm
how can i get the virtual dj mixer because i want to use that in my laptop so that i can play all my favorite songs at this minxer
geposted Tue 13 Apr 10 @ 6:18 am
This is totally off point in this thread.
You are not experiencing an installation error.
Please check your sound card settings as this is what causes what you are describing.
If you have further problems, please post them in a new thread.
geposted Tue 20 Apr 10 @ 2:14 pm
HOLA DESDE MEXICO, TENGO UNA HERCULES RMX PARA VIRTUAL DJ, MI PC TIENE 2GIGAS EN RAM Y UN DISCO DURO DE 500MEGAS,
LA PC TIENE INSTALADA LA TARJETA DE SONIDO (CREATIVE SB AUDIGY E480), QUE MEJORO TOTALMENTE EL SONIDO, EL PROBLEMA QUE TENGO ES QUE TENGO INSTALADO EL SOUND FORGE 10, PERO AHORA EL HERCULES NO ME PERMITE GRABAR EN EL SOUND FORGE, ME BLOQUEA Y DESCONFIGURA.
-SOLICITO SABER SI SE NECESITA ALGUNA APLICACION PARA QUE NO SE VAYA A SEGUIR CREANDO ALGUN CONFLICTO CON LAS 2 TARJETAS DE SONIDO (HERCULES RMX Y AUDIGY E480).
tambien solicito me indiquen si es necesario en donde poner este tema de ayuda, aqui en el foro....
GRACIAS Y AGRADEZCO SU ATENCION
RICARDO LOPEZ
MEXICO.
RICARDO LOPEZ
MEXICO.
geposted Wed 19 May 10 @ 10:41 am
djricardolopez,
1) Este es un sitio en inglés. Debe escribir en inglés en este foro. Si quiere hablar en español, use el FORO EN ESPAÑOL.
2) El tema de esta discusión es ERRORES DE INSTALACION? DESHABILITE el Antivirus NOD32. O sea que usted está totalmente fuera de tópico.
3) Si quiere quitarse broncas, use VirtualDJ Pro. No requiere grabar en Soundforge para grabar una sesión de VirtualDJ. Grabe en WAV y luego conviertalo a MP3.
4) Si quiere más información refierase a EL FORO EN ESPAÑOL y/o aqui: http://www.virtualdj.com/contact/index.html
No escriba más en español aqui, y tampoco conteste este post. Hágalo en el FORO EN ESPAÑOL y/o los tickets de soporte técnico que le describí.
ACW
Atomix Productions
ACW
Atomix Productions
geposted Fri 21 May 10 @ 12:49 pm
I have Pioneer CDJ-400 2pair and DJM-400 with Virtual pro how can use it,i want to feel what am playing on virtual on my CDJ and the Crossfader on my DJM to work with it as well do i need a sound card to do that.....i only know about Native Instruments TRAKTOR SCRATCH PRO that works with Pioneer so tell me how i can do it with Virtual Dj.....Need help in time.
geposted Mon 21 Jun 10 @ 7:05 am
