A - Is there a VDJ Default Skin for 17" Laptops?! 1440x900
I like the vdj default skin!
I use it with my DJ CONSOLE, but i bought a new laptop. Toshiba P35-S609 with 17" widescreen LCD display.
Is there a default skin for this 1440x900 display?
Thank you.
Thank you.
geposted Wed 09 Mar 05 @ 10:03 pm
you can do it by your self
make a copy of the original skin
modify the copy of the original skin
use the guide:
http://www.virtualdj.com/support/developers/skin.html
you can do the skin 1440X900
you can do a skin 100X100 if you want
you are able to do this
use the guide:
geposted Thu 10 Mar 05 @ 4:18 am
