Is there a way to save a que point for a song permanently?
I set a que point and then when i start VDJ at a later time, the que point is not set.
Thanks, Rod
Thanks, Rod
geposted Wed 09 Mar 05 @ 10:12 pm
I'm not sure what are you (or software is) doing wrong, but CUE points are always rememberd, when once set. They are saved in the file (Virtual DJ database.xml), where all song info is stored. So unless you're having problems with the database, I have no idea what is going wrong. Someone else should help you with that, or you'll have to try rebuilding the database by deleting it, and restarting VDJ. Note: All song info will be lost with deletion!
Regards.
Regards.
geposted Wed 09 Mar 05 @ 10:18 pm
Quit moving your tracks around outside of vdj and it will remember them.
geposted Thu 10 Mar 05 @ 1:22 am
Actually, you can move tracks around, but do not rename them and do not change them in size at all (setting tags on your mp3s can also change the size of the file).
Killabee44
Killabee44
geposted Fri 11 Mar 05 @ 3:43 am
You can rename them from within virtual dj without problem, but one at the time, no mass-renaming -something i do sometimes- (like tag & rename)
geposted Fri 11 Mar 05 @ 4:44 pm
