What i like to see is the possibility to store loops in the sample section which can handle more than 4 beats....
So i can program acapella's for instance with beatlock
geposted Sun 03 May 09 @ 8:48 am
Loops aren't limited to 4 beats - if you have a track currently looped when you record the sample it uses that loop length.
geposted Sun 03 May 09 @ 5:28 pm
@sbdj.... So why have i always thought the freakin loops were 4 beats? could made a lot of money knowing this haha....
tnx!
Joop
(ps... how's the sms-text going?)
tnx!
Joop
geposted Mon 04 May 09 @ 6:24 am
Because no body reads the manual ...
pg 44 ...
"To record a circular (looping) sample, use the deck’s loop control to set the loop then click the “Loop” button on the bottom of the sample cell. The loop is automatically recorded to that sample cell and ready for immediate use.
If the “Loop” button is clicked without defining a loop using the deck controls, a 4 beat loop is automatically recorded."
geposted Mon 04 May 09 @ 12:00 pm
In built EQ/Kills on the sampler section would be very useful..or can I do that already? I ponder.....play from deck with EQ already adjusted with VDJ internal mixer and get a recorded EQ' version of that sample? hmmmm...will have to try that! :-)
geposted Sun 10 May 09 @ 2:35 pm
Rubbish!...yer EQ on sampler please.
geposted Sun 10 May 09 @ 2:37 pm
Use a triple output sound card and run the sampler to it's own channel on a mixer. Far more flexibility :)
geposted Sun 10 May 09 @ 5:42 pm
Doing that with Timecode but I often use 2 or more sample to spice up dull transitions. Effects are cool but making good use of the auto matched samples is a good way to hype a crowed....+ it makes me sound like a god!! haha I was accused of just playing a DMC mix's saturday night cos mixing / remixing like that cant be done live...a great compliment I thought!! Ok..it was rehearsed..but still. :-)
Anywho, with EQ's on each sample output I feel I could push it further before its sound messy.
geposted Mon 11 May 09 @ 3:36 am
ok then.... let me put one more in:
IS it necessary to take a sample at each bpm (and save it) to use the sample in its original pitch, because the pitch is shifting along with the bpm change....
or am i overlooking some page again?
gr,
Joop
gr,
Joop
geposted Mon 11 May 09 @ 8:28 am
Yup, but controlling multiple EQs on multiple samples would become messy. The best solution would probably be to have dual sampler outputs, so you could do a 4ch output to two seperate channels on a mixer for decks, and 2 for sampler.
Or more decks.
This is where software like Ableton and Mixmeister come into their own.
geposted Mon 11 May 09 @ 10:04 am
gr,
Joop
gr,
Joop
You are correct, sampler output is pitch shifted rather than time stretched.
geposted Mon 11 May 09 @ 10:05 am
Yeah, that would probably be asking a bit much of most people's computers to have 12 independently-running timestretch engines for the sampler!
geposted Sun 31 May 09 @ 8:23 am
