nai bre alla sou leo oti to thelo se ena koumpi!
kai sketo hotcue kai auto pou leme!
de thelo 2 diaforetika koumpia.....
tespa douleuei kai etsi.
geposted Mon 09 Nov 09 @ 9:31 pm
ante ante perimeno!
tha prolabo na ti balo prin pao gia douleia simera?
geposted Tue 10 Nov 09 @ 7:27 am
ti katebazooooooooooo
geposted Tue 10 Nov 09 @ 8:17 am
search in greek and russian can use transliteration
telika itan auto pou eipa.
kalo!
kalo!
geposted Tue 10 Nov 09 @ 8:34 am
VirtualDJ 6.0.3 (9 November 2009)
Improvements:
* Windows 7 compatible [PC]
* soundengine quality improved in safemode [PC]
* can drag and drop files from within virutaldj, by pressing CTRL when dropping over a folder
* don't add to searchdb files that are not physically present (from itunes, history, playlists, etc)
* added timecode engine v4
* optimized memory managment
* search in greek and russian can use transliteration
* space in search matches '-' or '_'
* better layout in the mapper dialog
* new action: set_gain, preview, loop_button
* new timecode debug option: smooth pitch
* new config/option: vinyl mode
* new folder context menu: create subfolder
* open in explorer selects the file [PC]
* forced mix starts from the selected transition type's entry point
* added CDJ2000, CDJ900
Fixes:
* fixed random search crash [PC]
* fixed random graphic crashes [MAC]
* fixed crash on v5 skins with v6 actions
* fixed crash on reload itunes subfolder
* fixed pops with equalizer and safemode [PC]
* fixed videos with multiple AC3 tracks
* fixed "goto -1" to stay in sync
* fixed set_cue sometimes not saved
* fixed goto_cue and hotcue when looped to keep the loop
* fixed headphone_mix in automix
* fixed no long sort on filedate
* fixed smart_scratch in reverse mode
* fixed djc_button_popup
* fixed sort in playlist reload next track if changed
* fixed click on coverflow keeps selected song in view
* fixed fade to black kept if disabled
* fixed dump can stay stucked
* fixed volume keys on keyboard for shortcuts [PC]
* fixed unicode in karaoke zip [PC]
* fixed unicode in playlist/history [PC]
* fixed unicode in broadcast infos
* fixed unicode and accents in search box
* fixed case insensitive search for unicode chars
* fixed action learn on mapper page [MAC]
* fixed missing jogwheel sensitivity (bend) option [MAC]
* fixed backspace removes songs from playlist [MAC]
* fixed save soundconfig changes when leaving the page
* fixed drive column [MAC]
* fixed stealth and omni mappers
* fixed ns7 platter speed not correct
* fixed ns7 sound jumps when beattap or scrolling in songs
* fixed hercules steel definitions (right stop button)
* fixed Hercules Trim audio
* fixed Hercules RMX audio in loopback mode
* fixed CDJ400
Improvements:
Fixes:
* fixed CDJ400
geposted Tue 10 Nov 09 @ 11:11 am
auto to preview akoma na to ftiaksoun!
pali kolaei.....
pali kolaei.....
geposted Thu 12 Nov 09 @ 7:17 pm
Min gkriniazeis aledjo... den ksereis posy douleia peftei kai posa ftiaxnontai kathe fora.
Einai gnosto problima pantos.
Gia preview fortoneis sto player pros to paron opos kaname panta me ta cp kai ta pikap...
geposted Fri 13 Nov 09 @ 1:48 am
meta apo 4 mines, simera me tin ekdosi 6.0.3 tsoup!
Crash ID=004d858e (date=911182324, version=6.0.3 Pro, build=603, thread=Scan, dump=f3a5ff24, excode=c0000005 (0,2ff1000))
ti lene oi eidikoi??
geposted Wed 18 Nov 09 @ 6:11 pm
Pano pou xarika kai ego...
Dose plirofories ti ekanes ekeini ti stigmi kai an mporeis na to anaparagageis me ton idio tropo.
geposted Wed 18 Nov 09 @ 6:55 pm
auto pou ekana ekei ti stigmi einai kati pou kano kathe mera!
fortosa to "yparxei zoh" sto aristero deck kai afou eixe fortosei to ebala na paiksei gia na to akouso apo ta akoustika.
e ekei petakse to gnosto parathyro kai afisa na paizei to deksi deck mexri na kano allagi me cd.........
simeiosi oti apokleietai na ftaiei to tragoudi giati to paizo tosous mines kai den exei ksanaginei auto.
ti lene oi kodikoi tou sfalmatos? ti lene oti ftaiei?
geposted Wed 18 Nov 09 @ 7:02 pm
Otan les to akouses sta akoustika? me to "ellatomatiko" preview i mesa apo mikti, i exeis ta akoustika stin rmx kai kaneis preview ekei ?
geposted Wed 18 Nov 09 @ 7:06 pm
to eixa fortosei sto aristero deck tou vdj kai to akousa apo tin eksodo ton akoustikon tis rmx!
(de xrisimopoio to preview)
opos kano edo kai toooosous mines diladi
les na ftaiei i rmx? de nomizo...
geposted Wed 18 Nov 09 @ 7:15 pm
a kai tora pou to thymithika, eno to akouga apo ta akoustika, to pigena mpros piso me ta koumpia |< >| epano apo tin rmx.
geposted Wed 18 Nov 09 @ 7:19 pm
ok to anebasa... pao na koimitho aledjo..
geposted Wed 18 Nov 09 @ 7:21 pm
kalinyxta apopsis!!!!!!
geposted Wed 18 Nov 09 @ 7:24 pm
paidia gia dokimaste kati gia tha trelathw...
To VDJ exei default to search sto ctrl+F. Dokimaste na to alalksete kai na balete opoiodipote allo plikto (oxi syndyasmo). Ti sas vgazei?
Emena mou vgazei panta enan xaraktira, pou tha eprepe na afinei to search field keno. Akoma kai to space afinei ena keno....Exw dokimasei ta panta..(oxi to Ultrex akoma).
geposted Wed 18 Nov 09 @ 8:51 pm
Nai exeis dikio kai ego to anakalypsa xtes, exo to space gia search...
To anafere o acwdj idi sto forum gia bugs.
geposted Thu 19 Nov 09 @ 3:33 am
nai auto ginetai kai se mena.
i moni lysi einai na baleis to backspace!!!! xexexe
apopsis exoume kanena neo gia to sfalma? eimai periergos na do ti tha poun oti ftaiei.
geposted Thu 19 Nov 09 @ 8:03 am
exo mia aporia tin opoia kapou eixa diabasei paliotera edo sto forum.
ginetai na exoume ta idia efe pou exoun ta cdj100s sto vdj?
mazi me tin rmx kai fysika na pernoun ton elegxo ta jogs.....
geposted Fri 20 Nov 09 @ 7:30 am
ta 100aria exoun aparadekta fx, swsta?
nomizw pws patwntas ena ap ta effecs (dn 8ymamai poio vevaia), k gyrnwntas to jog-wheel, allazei to key tou kommatiou. dior8wste me an kanw la8os vevaia.
geposted Fri 20 Nov 09 @ 7:42 am
