Logika apo oti eida den exei kanei mapper, apla exei grapsei to definition.
Simainei oti tha valeis to xml arxeio sto Eggrafamou/VirtualDJ/Devices kai meta apo to config/mapper tou VirtualDJ tha mappareis opws theleis tin syskeui. Prepei na stin deixnei stis syndedemenes syskeues, apla den tha exei kammia leitourgia assigned.
geposted Fri 30 Apr 10 @ 5:09 am
Den fenete tpt.Pataw to rescan for new devices alla me giwnei kanonika.kai mesa sto fakelo devices den yparxei kai tipota allo einai kenos ektos apo to apc 40 xml. pou evala den 8a eprepe na yparxoun kai alla xml. arxeia?
geposted Fri 30 Apr 10 @ 6:50 pm
ok kati arxisa na kanw to kolima twra einai na brw pws 8a diaxwrisw to aristero me to deksi deck.
e re pedema xaxa.
e re pedema xaxa.
geposted Sat 01 May 10 @ 5:27 am
Auto me to apc40 me endiaferei kai emena, den to exo alla eimai metaxy...apc20, apc40 kai Novation Launchpad...
Pros to paron kanena den ypostirizetai akoma me default mappers kai ayto giati i Akai kai i Novation theloun na kratisoun to protokolo kleisto den den synergazontai idiaitera. Eytyxos opos eides yparxei tropos na ftiakseis diko sou mapper kai to dyskolo kommati einai to definition file.
Katarxin steile ena pm ston typo pou ekane to definition mipos exei kanei kai kapoion mapper kai den ton anebase, na min paideyese.
Tha ton breis edo (einai germanos):
http://www.virtualdj.com/homepage/nici_the_kyd/index.html
Kai krata mas enimerous.
Mia erotisi pou thelo na kano, xoris ton mapper kai an theleis px na elenkeis opoiodipote midi programma, yparxei dynatotita kapoia button sto Apc40 na ta doseis stathero fotismo (eno ta alla na einai sbista), oste na dimiourgiseis ena layout pou se volebei ?
Katalabaineis ti enno, opos einai to matrix me ta button, px na fotiseis enan stayro opos ta pliktra up,down,left,right sto keyboard.
An i apantisi einai nai ti xroma ? kai epeisis na allakseis symperifora button/on-off ?
geposted Sat 01 May 10 @ 8:51 am
mporw apo tn mk2 n kanw t exhs?? : epeidi exei exodous minijack kai RCA 8elw n steilw ston enisxiti hxo apo RCA kai se ixeia pc hxo apo minijack ... milame panta g tn idia exodo .[ px. 1/2 ] ginete?
geposted Sun 02 May 10 @ 7:31 am
Tautoxrono output apo minijack kai RCA?...Xmmm dokimase to alla exw tin entypwsi pws otan xrisimopoieis to ena apo ta dyo to allo prepei logika na apomonwnetai...den kserw.
geposted Sun 02 May 10 @ 9:49 am
Apopsis den nomizw na yparxei tetoia dinatotita toulaxiston stin apc 40 kai oute kai sto manual anaferei kati tetoio.
to mono pou kanei i konsola einai oti an einai se katastasi anamonis kai den exeis sindemeno to usb tis panw sto pc arxizei ena random lighting olwn twn koumpiwn tis san epidiksi kai an patiseis opoiodipote pad i slider afto sinexizei ton xava tou.
Me ka8e epifilaksi.
Isws na yparxei kapoios tropos alla den gnwrizw parapera.Oi mages to vgalan nte kai kala gia to ableton ekei to mixanima ta spaei.
Asxeto.An einai na agoraseis tin konsola partin apo ellada egw tin pira mesw ebay apo ameriki me arxiki timi 230 eurw (ti wraia)kai edw me skisane sinolika na glitwsa kana 50ariko kai an ou mi geneto pa8ei kati psakse ta amerikanakia.Ase to xrono anamonis apo ameriki mexri ellada 2 meres kai stin ellada 3 evdomades xaxaxa xwris plaka 3 evdomades ta tsakalakia.
Me ka8e epifilaksi.
geposted Mon 03 May 10 @ 2:25 am
Mou apantise simera kai o tipakos pou ekane to definition den doulevei allo leei to vdj me tin apc40 opote geia sas me to mapp.
geposted Tue 04 May 10 @ 3:23 am
Καλησπέρα σας!!! Έχω εγκαταστήσει τόσο την έκδοση 5.2 του VDJ όσο και την 6.08 (εγκατέστησα την 6.08 πιο πρόσφατα). Έχω προσπαθήσει να αντιγράψω τα BMP και XML αρχεία των Pro Skins του VDJ 6.08, στη Database του VDJ 5.2 (επειδή έχω ρυθμίσει όλα τα Cuepoints των κομματιών μου στην έκδοση 5.2 και θεωρώ ότι η ρύθμιση όλων των Cuepoints ξανά στην έκδοση 6.08 αποτελεί αχρείαστη απώλεια χρόνου). Όταν πάω να επιλέξω ένα skin που εξαρχής προοριζόταν για το VDJ 6 (π.χ. Pro (Hi-Res)), μου εμφανίζει πρόβλημα στην ανάγνωση του skin λόγω XML file error (ακριβές μήνυμα: Invalid Skin File (error line **** in the xml) ). Για τον παραπάνω λόγο θα ήθελα να σας κάνω 2 ερωτήσεις:
1) Υπάρχει κάποιος τρόπος να μεταφέρω τα Pro Skins του VDJ 6 στο VDJ 5, χωρίς να υπάρχει πρόβλημα με την ανάγνωση των skins?
2) Εάν δεν υπάρχει λύση στο ερώτημα (1), θα ήθελα να ρωτήσω εάν υπάρχει τρόπος να μεταφέρω κάποια database με όλα τα Cuepoints από το VDJ 5 στο VDJ 6, ώστε να μη χρειάζεται να ξαναρυθμίσω όλα τα Cuepoints στο VDJ 6.
Θα σας παρακαλούσα να μου απαντήσετε πάνω σε αυτό το θέμα το συντομότερο δυνατό.
Σας ευχαριστώ πάρα πολύ εκ των προτέρων για την κατανόησή σας και τη βοήθειά σας.
Με βαθιά εκτίμηση,
Γιώργος Κυριακάκης
Με βαθιά εκτίμηση,
Γιώργος Κυριακάκης
geposted Tue 04 May 10 @ 6:43 am
Το πρώτο που ζητάς δεν γίνεται (skins της έκδοσης 6 να παίξουν στην έκδοση 5)
Το δεύτερο που θες γίνεται αυτόματα κατά την εγκατάσταση του VDJ 6. Το πρόγραμμα μετατρέπει αυτόματα τις βάσεις δεδομένων της έκδοσης 5 σε βάσεις δεδομένων της έκδοσης 6 χωρίς μάλιστα να πειράξει τις βάσεις της 5.
Διαφορετικά σε κάθε εκκίνηση του προγράμματος όπου υπάρχει βάση της έκδοσης 5 και ΔΕΝ υπάρχει βάση της 6 το πρόγραμμα σε ρωτάει αν θέλεις να δημιουργήσει την βάση της 6.
Κατά την δημιουργία των βάσεων της έκδοσης 6 αντιγράφονται ΚΑΙ τα CUE-Points....
geposted Tue 04 May 10 @ 8:04 am
Exw mia erwthsh.
Otan exoume energopoihmeno to automix sthn playlist mas den tha mporouse na exei mia akoma epilogh sto automix type pou na legete "cue" kai na teleiwnei automata to komati sto teleutaio tou cue kai na fwrtonei to epomeno automata sto prwto tou? (enoeite oti kalo tha htan na yparxoun kai rythmiseis gia xrono tou cross fading kai beat sync -smart/on/off- klp)
mhpws yparxei kapoios tropos kai den to exw parei xampari?
geposted Sun 09 May 10 @ 11:47 am
Den xrisimopoiw pote automixing, den mporw na sou pw an yparxei lysi i oxi, alla skepsou ligo.. an ypirxan ola auta pou les kai alla tosa, emeis ti tha kaname? tous programmatistes? lol !!!!
geposted Sun 09 May 10 @ 2:02 pm
re magkes thelw na kanw mia erotish ! mipws xerete pws mporw meso tou virtual dj na ftiaxnw dj drops me to onoma m kai kapoia efe !an se kapoious einai gnwsto tha ithela poli na xerw ;)
geposted Sun 09 May 10 @ 5:29 pm
Sorry, alla den ksero kanenan magka edo, kserei kanenas allos re paidia ?
geposted Sun 09 May 10 @ 11:37 pm
gorgones nai...magkes ...mpaaaa...
geposted Mon 10 May 10 @ 4:24 am
egw san kalh gorgona mporw n sou proteinw 2 tropous...
1) n t hxografhseis esy h kapoios allos m ena mic kai sto audacity
2) n mpeis sto
http://www.radiodaddy.com/index.php
k n zhthseis n sto kanoun. an eisai tyxeros 8a t exeis! diavase omws tous kanonismous k genika ton tropo leitourgias tou site...
2) n mpeis sto
geposted Mon 10 May 10 @ 5:21 am
programatistes e? panda mou aresei na skaw oso to dynaton kalytera proethmasmenos kai organomenos isws gi auto na skeftomai etsi.... tespa katalava den ginete :)
geposted Mon 10 May 10 @ 11:21 am
Mporeis na rythmiseis intro kai outro point gia kathe tragoudi sto automix...
Edit bpm se tragoudi pou einai fortomeno ston player kai tha deis tis epiloges..
geposted Mon 10 May 10 @ 12:04 pm
oxi re file me esteiles! kati einai ki auto toulaxiston!
ta mix cut kai mix tempo ti einai?
tespa tha to psaxw euxaristw poly!
geposted Mon 10 May 10 @ 12:20 pm
kalhspera.
palaiotera xrhsimopoiousa to hercules mk2 me thn eidikh eksosh tou vdj. Twra xrhsimopoiw to rmx me to teleytaio vdj pro kai parathrisa oti patwntas to koumpi "sync" den menei on mexri na to ksanapathsw. Einai 8ema tou rmx h tou vdj ayto? Kserete pws mporw na to allaksw?
thanxxxx
thanxxxx
geposted Wed 19 May 10 @ 6:36 pm
