Topic: 10 minutes
Why does the Virtual DJ software can't "load" properly tracks that have more than 10 minutes? And why does it crash when a play one of these tracks? If anyone know how to solve this problem, I would apreciate some help there.
geposted Wed 23 Mar 05 @ 8:01 pm
Hum... maybe this problem comes from your 2.01 cracked version ? No ?
We don't support any cracked version
Regards
geposted Wed 23 Mar 05 @ 8:08 pm
The 2.0.6 version includes a maxload setting in the configuration. This is set to 10 minutes by default. If you are loading songs longer than 10 minutes, you probably want to change this.
geposted Thu 24 Mar 05 @ 12:05 am
Yes but this setting don't cause a crash when the song is longer than the setting.
A cracked version is not the better way to test a software, you can see a bug, a crash and you are sure this is caused by the program (and in reality it's caused by the crack...) Thats why we don't support the craked version
Regards
geposted Thu 24 Mar 05 @ 1:50 am
