Forum: Old versions
Topic: Djm 800 and Midi
Hello everyone, I need help on mapping my DJM-800. I want to use 1,2,3,4 Fader start as my loops. 1 and 2 would be for my left deck and 4,8 beet loop, while, 3,4 would be my right deck 4 and 8 beet loop. I mapped the left side everything's fine. When I map the right side, 3 and 4 buttons, it maps the left deck, which is already mapped. I tried to map the right side first then the left, but no luck. Can someone tell me what I am doing?
Syberman
geposted Wed 03 Jun 09 @ 12:35 pm
If you are mapping for specific deck actions preface the action with -> deck 1 <your actions> or deck 2 <your actions>
Example --> deck 1 loop 4 <-left deck and deck 2 loop 4 <-right deck
Thanks cstoll, will try and post in a few.
Syberman
I cannot find where it says "Deck 1" or "Deck 2" in the drop down.
Syberman
You type it in the Action textbox
I'm sorry to be noobish here, lol! What should I type???
As I gave you above ... in the action box you first say which deck then the action you want to happen on that deck ...
So a button that I want Deck 1 to do a loop on 4beats --- > deck 1 loop 4
And if I want the same on a different button for Deck 2 ---> deck 2 loop 4
Thanks cstoll, I will try it. At work right now!
Syberman
Hey there syberman. I have an 800. If you still have issues, I can do the midi map and send it to you.
hi, just asking from your pc to mixer (djm 800 five din plug ) what midi unit are you useing ,as i would like to midi my djm800 or any one got any think better!
I'm using M-Audio midisport 2x2 USB midi box. I got 2x2 in case i needed to add another midi down the track but haven't needed it so far. It's been regularly chucked in and out my gig bag for over a year and have never had a problem.
My full gear list is on my page for reference.
Hope that helps.
thanks BISH , for that it look good are you running xp or vista 32 or 64 just asking about timecode cds ?
Thanks Cstoll for your help, I got it to work. Thank you. And thanks Bish for offering the midi mapper.
Syberman
Running xp.
So that I usnder stand here in the new VDJ you can script your mappings?
Like if I want the Deck 1 and Deck 2 voulume and just the cross fader to corispond with the internal fader I have to type it in the box?
Also sorry for noob question I still havent got mixer to work!!! :(
I believe the crossfader you can easily map, but for the volume, you have to type deck 1 and deck 2 in the action box. Did you get the DDM4000 mixer?
Syberman
Yeah I got it I even got it to reconize in VDJ as midi device. But I have read and read but cannot get the dam thing to work? all I want is to controll the software like the 800 will? I may just use the RMX as a sound card anyways since I am moving twards video's now!!!
Do you have a USB to midi cable from the mixer to your computer? If you don't have that, it will not work the way you want. When I had that mixer, I mapped so many things, I hardly ever touched my laptop.
Syberman
Yeah I have one its a $13 one but I guess I may have to get one of those $30 one since the light never goes green? also I am taking the mixer back because I get grounded when I touch the edges? thank god my friend gave me the reciept for it before he left?
When I bought the DDM4000, I bought the M-Audio Uno USB to midi as well. I have no complaints at all with it. I am using this with my djm 800. And still no complaints.
Syberman
