Forum: VirtualDJ Skins
Topic: vdj 6 skin modification
hi all just a quick question is there any skin makers out there could modify a couple of skins for me (i know nothing about skin making) first one is the pcdj vj phantom skin so i can get access to sampler etc, the other is the normal vdj 6 skin all i'm looking at changing on that is the icons in the record case from what they are to karaoke being the blue speaker, audio yellow, and video the blue windows icon are either of these possible?
geposted Fri 05 Jun 09 @ 3:16 am
kev, the second part of your request (the browser required no coding. Just load the BMP image from the ZIP files into something like Photoshop or even Paint and change the icons yourself.
Please post a screen shot of the phantom skin you talk off and i'll take a look at it.
geposted Fri 05 Jun 09 @ 6:30 am
geposted Fri 05 Jun 09 @ 7:28 am
that'll be the one above
geposted Fri 05 Jun 09 @ 11:15 am
Its on the PCDJ community forums. if you search around, you can find it there.
geposted Sun 07 Jun 09 @ 10:51 am
