Hi,
I could not find it with the search function but I assume it should be there somewhere..
When I save a sample in Cue (VDJ) then it is stored with its own extension. But I would like to use the samples also in other software so I need then as WAV files. Is the possible or can I convert them?
Best regards, GWsound
geposted Mon 15 Jun 09 @ 11:22 am
I create a lot of my own samples. I save them as mp3, you can use .wav files though. Save them at a high sample rate (over44100 HZ). Then select the file for use with the sampler. Hope that helps.
geposted Mon 15 Jun 09 @ 11:27 am
Vdj saves samples in ogg format. You need to open the file in a hex editor and remove the first 44 bytes of it (so the file beings OggS). You can then rename it to .ogg and convert it with whatever software capable of doing so, e.g. dbpoweramp, winamp, ffmpeg etc.
geposted Mon 15 Jun 09 @ 11:58 am
Thanks for the help I´m going to digg into HEX files. The reason is that I created really nice loops in VDJ and do not like to create them again.
Gwsound
Gwsound
geposted Tue 16 Jun 09 @ 2:16 pm
