Topic: Loop in / out
What's the difference with shift_loop?
Is it something totally different or not?
GnoedeL
geposted Thu 07 Aug 03 @ 12:57 am
Shift_loop enable you to move a seamless loop (or the new loop in out actions) x beats forward/backward
The loop in /out actions have been added to be able to set a loop in point and a loop out point without having to count how many beats it represents.
thx
Man I love the Loop In/ Loop Out.
Hours of fun.
Thanx and Well done guys. :)))
All you need now is more than two decks and youre coming close to perfection
Well you can have more than two decks you know, just not in the same instance of VDJ running. ;) I usually open up two instances so I have four decks to mix with.
when setting keys for each deck to activate these, should there be a value?
Also should reset be selected as i dont seem to be able to drop the loop?
Stu
Multi-instance isnt good enough
You need to be able to see all three or four decks on screen.
Not nescesarrily the waveforms but you need the control.
Ive tried putting two instances side by side but you cant change the size of them
stuxxx: Loop in & Loop out dosen´t need any value.
For exit the loop just set a loop shortcut with value 0
thanx DJ Coco
Stu
