Forum: Old versions
Topic: MK2 as a asio soundcard
Hi all
Just wanted 2 knw if any1 is using the mk2 as a soundcard for their cdjs or tts with vdj? Hows the sound quality, latency, etc? I'm planning on getting a mk2 and using it as a asio and mixer at a later stage.
geposted Fri 07 Aug 09 @ 12:28 pm
MK2 with its asio driver work very good.
Yes i mostly used the mk2 as my soundcard with cdjs or tts and an external mixer at club and mobile gigs. It is ok and as it is a mid range card..it does do the job well;)
To enhance the quality it is best if you have external audio sound reinforcement unit too and also learn to eq;)
can the mk2 be hooked up to virtual dj using the serato vinyls
Yes you can use seratos time code, you must select it in the config-->Sound Setup-->Time Code Config
ok i did all of that can u plz walk me through the method what to select and all plz
Hello there the timecode now working with my vdj but the timecode is slipping how can i fix this plz help.
Hello djchrisjam,
Is the timecode slipping also if you set the timecode in Absolute mode?
I get error in the asio sound driver when i try to connect my MK2. i dont have a clue what is that. some help
I dont use the absolute mode i use only the relative mode.
how do u set everyting. because i keep having the same error with the asio sound driver. i dont know what to do
Hello djef0407,
If you have a message ' error in the asio sound driver' when you run VirtualDJ, it means VirtualDJ is set in ASIO while the Mk2 is not in ASIO mode.
You should switch your DJ Console Mk2 in ASIO (open DJ Console MK2 control panel, and change the Audio mode from WDM to ASIO) prior to running VirtualDJ.
