Forum: Old versions
Topic: New update Mapper Denon DN-S3700 VDJ 6.x - Page: 2
haz0rdPRO InfinityMember since 2006
Its rather simple attach the USB Cable start up Virtual DJ under mapper make sure HID/MIDI devices are enabled then scan
it will pick up the 3700 and its already mapped out. did this last week at GC it was painless... I am going to buy one next week!!
Thanks,
DJ SMG
geposted Thu 22 Oct 09 @ 1:01 pm
I'm a little confused about how to use the mapper. I downloaded the new mapper, but how do you actually input the updated mapper so that you can utilize it. I'm running a mac book pro and pretty much new to messing around with the mappers. Thanks in advance if you are able to help me and others who may have the same question.
geposted Fri 23 Oct 09 @ 9:09 pm
I have the same problem, I just bought the DENON DN S 3700, dowonloaded the mapper from the virtual dj site and I dont know how to make it work.... i open VD, selected to scan the device, but for some reason the computer is not reading the device....can someone help? I have a windows HP PAVILION
geposted Sat 07 Nov 09 @ 6:20 pm
cstollPRO InfinityMember since 2004
geposted Sun 08 Nov 09 @ 1:24 pm
DJCBPRO InfinityMember since 2006
geposted Thu 07 Jan 10 @ 9:28 am
Good job....Cheers....
geposted Thu 07 Jan 10 @ 11:54 am
i have virtual dj 5.2 a friend hooked me up,but i cant get my denon s3700's to work.any advice? it would be great to mix with this if i can please,help out
geposted Sun 05 Dec 10 @ 11:28 pm
You will need to upgrade to the latest v7.0.1 version of VirtualDJ.
VirtualDJ v5.2 is too old and has no support for Denon DN-S3700. There have been many improvements and changes to the software since v5.2
If you have purchased, please register your serial number by entering it in the boxes provided on the following page: http://www.virtualdj.com/users/edit.html - Then download and install the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
Otherwise, you will need to purchase VirtualDJ Pro from: http://www.virtualdj.com/buy/index.html
geposted Mon 06 Dec 10 @ 7:52 am
