Topic: Humming and airey sound from speakers - Page: 2
socrossPRO InfinityMember since 2004
geposted Thu 05 Jan 06 @ 2:16 am
dabethinc:
was the isolator you used rca to rca?
or was it ac power surge cord protector?
can you give me a model number from radio shack please
also, i am going to radio shack and pick up the pc800 power surge protector
thanks
geposted Thu 05 Jan 06 @ 5:59 am
It is an RCA to RCA cord.
The Radio Shack Model # is 270-054
I hope this helps you as well.
geposted Thu 05 Jan 06 @ 1:44 pm
geposted Thu 05 Jan 06 @ 1:46 pm
money in the bank!!!
thanks all
the hum is eliminated!!!!!!!!
i tried the srtip cord from musician's friend---eliminated the hum by only 10%
i bought the radio shack ground loop eliminator for $17 as dabethinc suggested as well as dj-in-norway
got rid of the hum
the definition of the sound quality is slightly diminished though....but the benefits far outweigh the slightly lower sound quality
thanks to all and to all a quiet system
geposted Thu 05 Jan 06 @ 6:37 pm
cyberiaPRO InfinityMember since 2004
@kramer101: did u end up getting 2 ground loop eliminators? Assuming you have 2 channels out of VDJ into the mixer, of course. Also assuming you have a TSR out to your amp/speakers.
geposted Thu 05 Jan 06 @ 8:31 pm
I had also the humming problem. From my laptop adapter powercord I chopped off the plug. I bought a separate plug and attached it to the chopped cord, without attaching the ground wire. In this case all my other equipment is grounded, only my laptop isn't.
The laptop itself is not grounded at all, while there are just 2 wires from the adapter to the laptop. Now only the adapter is not grounded. Seems pretty safe to me and verry cheap.
Ewout
geposted Thu 05 Jan 06 @ 8:33 pm
hi cyberia:
i did indeed purchase 2 ground loop eliminators from radio shack
i go from laptop to maya44 usb to mixer to powered speaker
i use one set of cables for turntable 1 and another set of cables for turntable 2
this fixed my problem, i hope it fixes yours too
good luck
geposted Fri 06 Jan 06 @ 5:13 am
