Forum: Old versions
Topic: 09/03 Java Update and VDJ
Weird... Yesterday, after I updated java version through Apple software update (a downgrade rather than an update, actually) both decks' play/stop/cue buttons of my DJC Steel stopped responding in VDJ 6.02 pro and 5.2.1 pro. Even if I press those buttons with a mouse click they won't work. I checked the DJC Steel with Midi Monitor and everything seems ok, so I guess this has nothing to do with the controller. I tried to reinstall VDJ but the issue remains no matter what. Is anybody experiencing this? Do you have any suggestions? Please help...
My configuration:
Early Spring macBook, OSX 10.5.8
Hercules DJ Trim + DJ Control Steel
geposted Fri 04 Sep 09 @ 9:19 am
Is your sound setting correct on VDJ?
Click to reset to factory setting at the info tab of VDJ and it may help.
Performance to best and latency auto.
Regards;)
It worked! Thank you very much for your help. That was so easy it made me feel like a newbie... shame on me.
BTW, could you spare some time on my other issue with right deck stop button of DJC Steel and VDJ 6.0.2? Here's the link to the thread:
https://virtualdj.com/forums/114836/MAC_Version_Technical_Support/6_0_2_fantastic__)_only_couple_problem_i_need_help_with_hercules_steel_right_deck_stop_button.html
Hope to hear from you soon!
Is Java necessary for the use of v DJ 7.4 pro basic? If so does it need to be up to date?
No, VirtualDj does not need/use Java.
Please do not resurrect 5 years old topics!
Topic Locked
