Ok check this. I really like VDJ. I don't use videos or eq. I like the pro layout. It would be cool if you could disable all the extras u dont use. That would really take some stress off the cpu and memory. Maybe im just thinking in timecode.What do you guys think?
geposted Fri 11 Sep 09 @ 6:21 pm
You can remove elements you don't use from the skin. If you leave features turned off or at zero setting, they won't be used and thus won't have any impact.
geposted Sat 12 Sep 09 @ 5:57 am
how
geposted Tue 15 Sep 09 @ 3:21 pm
