Forum: Balkan Forum - Topic: Problem sa virtual dj 5.0.1
(Serbia, Bosnia, Croatia, Slovenia, Montenegro etc).
Dobro došli na Virtual DJ forum! Pročitati pravila pre postovanja. Koristite pretragu.
VirtualDJ Forum
Balkan Forum
Problem sa virtua...
Autor - Topic: Problem sa virtual dj 5.0.1 -
dj funix
No license user
Posted Sun 13 Sep 09 @ 9:22 am
Kad upalim virtual dj,ubacim pesmu na jedan gramofon pise mi da je greska u skeniranju,onda mi izadje novi prozor gde pise,"ovo se nece ponoviti izvinjava se virtual dj automix" Ja opet upalim virtual dj isto se desava!!!!!!!
dj funix
No license user
Posted Sun 13 Sep 09 @ 11:13 am
Molim vas pomozite!!!! HVALA UNAPRED
DJ-ALF
Moderator
Posted Sun 13 Sep 09 @ 12:07 pm
Koristis staru verziju, probaj zadnji demo 6.0.1:
http://www.virtualdj.com/download/trial.html
dj funix
No license user
Posted Sun 13 Sep 09 @ 12:15 pm
SVE SAM PROBAO 5.2,6.0...NISTA NEUSPEVA MI
DJ-ALF
Moderator
Posted Sun 13 Sep 09 @ 4:48 pm
Moras malo bolje da objasnis problem da bi ti pomogli.
Dejamba
No license user
Posted Mon 14 Sep 09 @ 2:30 am
deinstaliraj pa onda:
drag the virtual dj folder from documents to trash
empty it.
Users/yourname/Library/Preferences/com.atomixproductions.virtualdj.plist
(your name means your username)
drag this file to the trash and empty.
reboot.
ocisti registry nekim od softvera
reboot.
instaliraj 6.0.1 pa reci sta se desava
dj funix
No license user
Posted Mon 14 Sep 09 @ 2:35 pm
Ne ide mi bas engleski,ako mozes ovo da mi prevedes bio bih ti zahvalan.
dj-dario11
No license user
Posted Tue 15 Sep 09 @ 3:48 am
JEDSNOSTAVNO OBRISI sve od VDJ-A sto imas i bilo bi dobro kad bi napiso kake gramofone imas koje atime codE ploce koristis koja verzija vdj-a kaki komp imas koju zvucnu nemos samo meni neradi i ja neznam engleskikako mislis onda da ti pomognemo ??
dj funix
No license user
Posted Tue 15 Sep 09 @ 7:16 am
Kao prvo ne zelim da dodjem do svadje,kao drugo ja nemeam gramofon,mislim na gramofon u virtual dj-u!!!!!!
dj funix
No license user
Posted Tue 15 Sep 09 @ 7:19 am
Konfiguracija kompijutera mi je:
Procesor:
Intel core duo 3,00 ghz,
Graficka kartica:nvide geforce 9800 gt
Ram memorija:3,25 giga
Hard disk:320 giga
Operativni sistem: windows xp
dj funix
No license user
Posted Wed 16 Sep 09 @ 5:46 am
Lepo ti pise u naslovu teme koji virtual dj koristim ,ima cak i jedan post gde sam napisao da sam sve verzije probao.....
DJ-ALF
Moderator
Posted Thu 17 Sep 09 @ 5:19 am
Koje fajlove koristis, Mp3, AVi? Probaj da ubacis neki audio cd pa prevuci traku na deck da vidis da li ce da je ucita.
dj funix
No license user
Posted Thu 17 Sep 09 @ 5:33 am
Koristim mp3,evo sad cu da ubacim cd
dj funix
No license user
Posted Thu 17 Sep 09 @ 5:37 am
Ubacio sam originali audio disk(sa pesmama),prevukao sam pesmu,opet isto,sta da radim mnogo volim virtual dj.
DJ-ALF
Moderator
Posted Sat 19 Sep 09 @ 11:15 am
Nesto tu bas ne valja, jesi li selektovao tvoju zvucnu karticu u Output opcijama?
dj funix
No license user
Posted Sat 19 Sep 09 @ 1:45 pm
Selektovao sam zvucnu karticu sve sam probao,opet sam prevukao pesmu sve isto.
