Forum: VirtualDJ Plugins
Topic: How do I load samples?
I have downloaded some samples from the VDJ website, but how do I get the sampler on my VDJ software to find them? I tried dragging them from the folder I downloaded them to, but this doesn't work.
Can someone help me, step-by-step please?
geposted Fri 02 Oct 09 @ 9:09 am
make sure you have the samples in a dedicated folder(s) is best.
when in vdj select samples tab
just below play button click on the "bullseye"
in drop down window select load
go to folder you have samples and double click on sample you want
re click on bulseye and from drop down select what you want to do with file loop, save etc
do this for each sample button.
hope that helps.
Damn, wish you posted that earlier terry, took me three days to type mine out.... lol
Yeah, I'm fast like that Paul. That's why Renee' will not let me visit... ;-)
I have some dj drops and also have the virtual dj pro 8 and I put my dj drops in the sample folder for virtual dj but when I am on virtual dj when I click on the sampler it only shows what virtual dj has not my dj drop but there in the sampler folder any suggestions or ideas thanks if anyone can help me out with this
Make a copy of the folder and paste the contents in the folder in my documents . Then sampler file and paste
The only way to load samples is to drag and drop them onto the pads.
I have the Denon MCX8000, and I'm trying to load my dj drops in the sampler and they won't load. I currently have the license, that is the only way I can use the VDJ software. Also there is a lag when trying to load a song. And what I mean is, After the song is loaded, and I've set the cue point, when I release, there's a sort of delay. How do I correct this?
Are you wondering why you've had no replies? It's because you've posted your questions in the plugins area. Your post has nothing to do with plugins.
It would have made more sense to post in the general area (but no, don't do it now because that'd be a duplicate post).
Also there's no need to bold your entire post.
OK so you're trying to load your "DJ drops". What format are they in? How exactly are you trying to load them? Read my earlier post (above yours).
There's a lag/delay when you release. Release what? How much of a delay? It could be that you need to adjust latency. Have you tried that?
DJ nadim
