Hello Everyone,
Loving every minute of the new VDJ 6. I have small suggestions, but one I brought up before:
1. Can you bring back the numbers for the sample banks? Helps me when I look at corresponding w/ my keys. I have a problem counting :)
2. When you right click on a track, the Remove is always first-Can that be moved to last? I've had VDJ for a while, but if I want to remove a track, I feel it should be last.
3. Will there be a possibility in the future to select multiple tracks to edit genre, album, and other info?
Thanks in advance.
Thanks in advance.
geposted Sat 10 Oct 09 @ 12:15 pm
Yes that would be a Big plus.
What I do Now is use MP3Tag Program to edit the tags for global changes and then reload tags in VDJ.
1. Make edits in MP3Tag program and save.
2. Highlight all those songs in VDJ browser.
3. Right click chose file info.
4. Then click reload tags option.
5. That will update tag info and covers into VDJ.
Here's the Link: http://www.mp3tag.de/en/
Good Luck
Joey.....
Good Luck
Joey.....
geposted Sun 11 Oct 09 @ 10:48 am
For now, I'll give it a try for tagging & I'm hoping in the near future VDJ will consider the select function...Thank you.
geposted Mon 12 Oct 09 @ 9:51 am
Hello !! How do you remove the sampler that you recorded? Thanks...
geposted Tue 17 Jan 12 @ 2:10 pm
You need to open a new thread I would say in tech forums, putting this in an old thread in the wishes and new features forums is the wrong place I'm afraid.
geposted Tue 17 Jan 12 @ 2:47 pm
Please start a new thread in either the PC or Mac support forums.
Thank you - Keith
locked
Thank you - Keith
locked
geposted Tue 17 Jan 12 @ 3:15 pm
